two eg B18C-R swaps, both have 1050rpm idle?
I have two EG9 with 96spec. jdm B18C-R swap.
They both idle at 1050rpm when warm?
I assume there is no vacuum leak, because when I disconnect IACV plug and turn the idle screw Im able to shut the engine with it.
Any ideas?
Any ideas?
Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">have you adjusted the idle screw?
which ECU are you using? (OBD1? is it tuned?)</TD></TR></TABLE>
Yes I have adjusted it. Idle stays 1050rpm when idle screw is fully closed. Then if I pull IACV plug off, engine stalls because it doesn't get any air..
Im using OBD2a ECU which came with the engines..
djmatix
08-11-2007 12:45 PM
