94ex to obd1-b16. can you just use the ex harness?
I'am thinking about doing a b16swap in my 94'ex. I will be using the stock p28 chipped to a stock b16 program. Can I use the stock harness?
Re: 94ex to obd1-b16. can you just use the ex harness? (wfocrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wfocrx »</TD></TR><TR><TD CLASS="quote">I'am thinking about doing a b16swap in my 94'ex. I will be using the stock p28 chipped to a stock b16 program. Can I use the stock harness?
yes thats exactly what you are supposed to use. All you need to do is seperate the O2 wires(not cut) form the main loom then they will reach to the O2 sensor location on the B16a which is closer to the cat on the exhuast manifold
gl
gl
thanks. what about mounts. I know it has been covered a miillion times; but, it seems that since b-swaps have been done so much everyone is just supposed to know what to do.
vtec69
10-04-2002 10:10 AM
