HCP H22 A/C Bracket into DC/EG
Okay guys Ive read about 100 post pertaining to this item, and I am closing up the parts real fast for my complete H22 swap into my DC4 and I will not go without A/C any more.
I dont think 10HP and 5lbs of fresh cold air on a hot summer day of 104 degrees will bother me!
I did read one post today that HCP discontinued this product is that true!?
I have a D series A/C Compressor already!
H22 Head
H22 LSD Tranny
DC VTEC Harness
OBD1 P28 Chipped
Axles
5th Gen Powersteering pump and bracket!
H22 block
Flywheel
Still need:
H22 Mounts into EG/DC
H22 Header
Exhaust
Test Pipe
Intake
Injectors
Clutch and P/P
HCP A/C Bracket!!
SIMPLE STUFF!!
Someone help me find this product, I found 448 post under archive and not 1 single post in recent!
H22 Head
H22 LSD Tranny
DC VTEC Harness
OBD1 P28 Chipped
Axles
H22 block
Flywheel
Still need:
H22 Header
Exhaust
Test Pipe
Intake
Injectors
Clutch and P/P
HCP A/C Bracket!!
SIMPLE STUFF!!
Re: (StreetRacinThug)
Yeah I'm not sure if HCP has disscontinued all their aftermarket motor mounts/ hardware cause I don't even see em being sold anymore, used to be able to get em and the ac bracket at jdmshit.com but now I don't know what's up.
Here ya go bud, seams like that last place that I can find that sells it.
http://www.racingworks.com/hcp...s.htm
Thanks man I found that site yesterday too !! but i wonder if they have it in stock i emailed them no reply, it just crazy too feel they actually have em...i appriciate your help and how is the H22 running in your DC2, qtr mile times and stuff or Dyno charts????
Yeah, not sure if they still have em in stock but hopefully they do... The h22's runnin great in my car finally. Haven't gotten a chance to dyno/tune it yet still waitin on some more money. Raced it back when it was stock and got 15.0 with really really crappy tires, hopin to race it again next season with it finally runnin good plus I/H/E.
Re: (skunked)
here a post with some good info about keeping a/c with your dc/eg that i made https://honda-tech.com/zerothread?id=1683991 Read that and if you have anymore question feel free to pm me.
The only downside to a/c for me is. A/C + Stiff Engine Mounts = Vibration Im trying to fix this but im pretty sure im outta luck. Yours might not shake as much tho since i have custom bushings which are prettty much rock solid.
Re: (lak8)
Some one clue me in on this one...H22's AC and Alternator run off the same belt inline what is the bracket for? The stock brackets with use of AC should clear the frame rail?
Re: (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">it's so you can use the Integra/Civic AC compressor if I remember correctly. Check out lak8's thread above.</TD></TR></TABLE>
Bingo Thanks skunked
Some one in that link i posted... or some information i came across before here on HT, said they used a h22 prelude compressor. Of course tho the lines to the compressor were custom/modded and the a/c had to be recharged afterwards. Im pretty sure this would also be a very tight fit
Re: (lak8)
If anyone wants a special bracket that will make use with the Civic/Integra AC compressor please PM me shouldn't be hard for me to make. -John
Re: (ESP.net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP.net »</TD></TR><TR><TD CLASS="quote">If anyone wants a special bracket that will make use with the Civic/Integra AC compressor please PM me shouldn't be hard for me to make. -John</TD></TR></TABLE>
jwerks
19
01-15-2008 09:23 PM
1320DRAGWORKX
08-02-2007 02:29 PM
Trbospnkr
06-29-2003 11:39 PM
