Wiring People I Need Your Help h22/cd5
Banned
I have a 1992 Jdm h22a in my 96 accord ex. My friend did the wiring about 2.5 years ago and everything ran fine until a few months ago. I fooled around with the intake manifold, putting the blacktrax iab delete plate in and hondata im gasket on. Now I have no vtec. I cleaned the solenoid, it has enough oil but is running a tad rich, but still should engage in vtec.
The harness that was used was the 96 accord ex stock harness and some parts from the prelude harness. Stock Ecu with a jdmshit obd2-obd1 harness. IT IS A MESS. I have no idea how to use a multimeter but dont know how to do pinouts and check to make sure the vtec pressure switch wire is still soldered together. My wiring skills are about a 3/10. any help would be great guys.
Re: Wiring People I Need Your Help h22/cd5 (JakeIsCool)
How do u know vtec isn't engaging? If it's not engaging then it should be giving u a check engine light, correct? If it is check and see what code it's giving you.
Banned
Re: Wiring People I Need Your Help h22/cd5 (JasonST)
its throwing like 5 codes. vtec oil pressure switch, tps, blah blah blah. the wiring for the op switch is fine, and the tps just needs to be calibrated. i think i found the problem, just need to find an accord wiring diagram.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeIsCool »</TD></TR><TR><TD CLASS="quote">its throwing like 5 codes. vtec oil pressure switch, tps, blah blah blah. the wiring for the op switch is fine, and the tps just needs to be calibrated. i think i found the problem, just need to find an accord wiring diagram.</TD></TR></TABLE>
wow... i would just work on 1 code at a time....
did u just get this car or what???
i would check the FAQ section of the accord forum for a diagram. they are very organized in there.
Banned
Re: Wiring People I Need Your Help h22/cd5 (hondaZvic)
no, ive had this car for four years, but vtecs stopped working a few months ago when i started dicking with stuff.
