motor=obd1 ..wanna convert motor to obd2
its a 94 integra motor. just wondering if i can reuse the sensors from the obd2 civic and put it onto the obd1 integra. IE: the map sensor, injectors and the fuel rail if it fits.
why would you want to do that? Use all the old sensors! OBD 2 and OBD1 plugs are the same, you will have extra plugs sometimes, also you have to get the conversion harness to use the 94 ECU.
Re: (07civicSI)
Depends on what ecu your running honestly; if your gonna use the obd2 ecu; your gonna have to buy and convert to an obd2 oil pump to run the crank sensor; injectors are easily swapped out so is the dizzy and alternator.
the car is a 96 hatch ...so i just have a spare ls motor which is obd1 sitting here..if its not hard to convert the motor over to obd2..id like to swap it into the civic...so can i use the sensors from the civic (obd2) and put it on the ls motor (obd1)? to convert it? everything else is good to go
Re: (Anti-Drama Queens)
Most of the sensors are plug n play. You can interchange OBD1 and OBD2 throttle body's, Map sensors, IAT's, coolant sensors, etc. IACVs are different, distributer plugs and alternator plugs are different. Injector plugs are different.
Jhonny Ricer
05-28-2007 12:02 AM
strictly.business
11-25-2006 09:05 PM
