NEED Help with headgasket and timing cover
i ordered a 84.5mm headgasket from GE and it turns out the block is toast, but i have a 84mm b20v taht needs a headgasket, can i use the 84.5 on my 84mm?
also:
i have a sohc vtec motor thats missing the upper and lower timing covers, can i use the timing covers off a sohc NON Vtec? or are they different? thanks in advance
also:
Re: NEED Help with headgasket and timing cover
i found out the timing belts are different, but what about the headgasket for the bseries? anyone?? come onnnn ttt
