Help b18c into my ek won't start!
Ok guys, I'm gonna try to be as thorough here as possible. Last week I swapped a USDM b18c into my 99 ek. Everything went in ok except for a few small bumps. I was told by the guy (craigslister) the motor was out of a 2000 gsr, he even had the invoice. Turns out that the dizzy was obd1 and so was the alt, shady I know. So I get a an adapter for the dizzy and spliced in an obd1 plug for the alt on my ek engine wiring harness. So all should be good. I plug the wiring harness into my chipped obd1 p28 and try to start the car. It cranks but doesn't sound quite right, it sounded like a pretty weak attempt to start then makes a weak, burbling backfire type popping sound, not a loud backfire that you would expect. So I check for fuel. It's getting fuel atleast to the rail, havent tried to pull an injector out and see if its getting fuel there. Next I check spark. No spark, atleast from what I can tell visually, the plug is not arking. I pull the plug wires off and use my multimeter in the hole where the wires go. It's getting voltage, I put it at the tip of the plug and its getting voltage there. I have new plugs and wires, so the problem doesn't lie there. I am thinking it may be the dizzy, but dont wanna get a new one if that isnt the problem. Anyone have an idea of whats going on here? Both grounds are on and solid too.
Re: Help b18c into my ek won't start!
That's s very common sound your talking about. If i were you I would check just about everything cause it sounds like this Craigslist guy wasn't exactly honest with you. Check all your connections, fuses, relays, injectors, combustion, compression, air box/throttle body. I mean everything! Make sure your wiring for the dizzy is hooked up correctly and also make sure you're timing is correct
Well upon further inspection I am getting spark. So I'm getting spark and fuel, timing is good as well. So I did a compression test. All 4 cylinders are at 0 compression. are my valves shot or what else could it be?
spags930
08-14-2010 11:45 AM
tigmandick
19
05-21-2010 10:13 PM
