Code 9 (CYP) JDM B18C '98 Civic DX
Old 12-12-2009, 04:21 AM
Sean EH2's Avatar
Default Code 9 (CYP) JDM B18C '98 Civic DX
yet another code 9 issue. i did search, didn't see anything too helpful.
fresh B18C (JDM "GSR") from hmotorsonline. 1998 Civic coupe DX. 1997 Civic EX harness.
throwing code 9 for CYP... before we go replacing distributors and such, is there a wiring discrepancy with this? using the OEM JDM OBD2 ECU that came with the swap, no OBD conversions. There is not a crank angle sensor near the oil pump.
where should we check first?
thanks!
Old 12-12-2009, 03:26 PM
AltimaXX's Avatar
Default Re: Code 9 (CYP) JDM B18C '98 Civic DX
Not sure. Sure is strange.
Old 12-12-2009, 07:12 PM
LA_HONDAS's Avatar
you have a obd1 motor so you need to do this \/ \/ \/ to fix your problem
http://www.ff-squad.com/technet/ckftrick.htm
Old 12-13-2009, 07:48 PM
912's Avatar
i was told code 9 is the magnets in dizzy
Old 06-02-2010, 07:05 PM
manoloek9's Avatar
i also have the same problem i did the ckf trick but i still get the code 9 cyp and my car still runs like sh**t! is there any other trick to fix this problem??? help please!!!
Old 06-06-2010, 08:15 AM
Nick97hatch's Avatar
Did you guys do the whole trick or just to bypass CFK? Cause they have a fix for code 9. I have done this and it works fine in my 97DX with a LSV.
Nick
Old 06-07-2010, 09:45 PM
manoloek9's Avatar
yes and still the same!
Old 06-07-2010, 11:11 PM
pitchblacksvt's Avatar
SAME PROBLEM HERE! I have done the wiring mod and have the same issue. What gives? I have been at this for 2 weeks now and nothin still code 9.
Old 06-07-2010, 11:16 PM
Is it me or most of us with this "issue" have gsr into civic dx?
-update- apparently the diagram from phearable.net that many are using to de-pin and re-pin is wrong and im waiting to hear back on how to fix this.
Old 06-16-2010, 07:43 AM
ekb16's Avatar
ive got a jdm gsr in my 98 cx and the trick worked for me
SiRCiviC94
03-02-2013 01:09 PM
halfabrotha
09-19-2003 07:05 PM
c-way
05-28-2003 05:01 AM
Jonathan_ED3
04-24-2003 04:45 AM
Quick Reply: Code 9 (CYP) JDM B18C '98 Civic DX
