ctr piston into jdm gsr motor
Old Jan 9, 2010 | 06:05 PM
soon2bdropped's Avatar
Default ctr piston into jdm gsr motor
ok does anyone know i got a jdm gsr i looked up the compression ratio and it is 10.8cr now i wanted to swap in 99=00civic si piston but i looked up the spec im looking at 10.2-10.4 cr. so if i do that im lowering the compression. also the gsr head has cams, and other valvetrain. so let me know if i can get away with the ctr pistons or not.. let me know guys.
or what pistons should i swap into that is a littler higher than the gsr but not outrageously retarded like the ctr. something midline but better than the stock gsr pistons.
Old Jan 9, 2010 | 06:38 PM
JDM JEFFREY's Avatar
Default Re: ctr piston into jdm gsr motor
where did u get the cr numbers from?
I would go with jdm p30s or ITR piston in a street motor
with the ctr pistons the cr will be too high for pump gas..
Old Jan 9, 2010 | 06:43 PM
Mr.Burner's Avatar
I'd use the ITR piston p73 JDM....
The ctr's are detonation kings unless you clean them up..and your compression ration will be 13.5.1.
the ITR is about 11:5:1, better for pump gas
Old Jan 9, 2010 | 11:44 PM
so using usdm b16 piston would actually decrease compression ratio right?
Bedgoodmrb
Dec 20, 2009 07:36 PM
401tuner
Jul 2, 2007 08:07 AM
jeremy.
199
Dec 23, 2004 03:45 PM
ziggen
Dec 28, 2002 09:09 AM
94gsr4d
Jan 29, 2002 09:31 PM
