B20B question
Old Jan 1, 2010 | 02:58 PM
UndisputedH22a's Avatar
Default B20B question
I have used the search button and been searching for just over an hour now and no luck..Well i need a new motor for my 98 Civic Cx Hatch like asap .., I wanna know before i buy a B20b long block what all is needed to drop it into my car and have it running...I want to just throw it in as a B20B non vtec swap for now.So can someone please come on here and please help me out with everything that is needed to put this motor in my car stock????Please?
Old Jan 1, 2010 | 08:23 PM
Default Re: B20B question
bump ttt please help!
Old Jan 1, 2010 | 09:35 PM
zfinatic's Avatar
Originally Posted by AGENT 99
I took the liberty of making a "NEED TO BUY" parts list for this b20>96-00 civic swap
MISC:
wiring harness
crv alternator +2 mounting bolts
94-00 ls starter + 2 mounting bolts
96-00 LS intake manifold- loaded
96-00 LS throttle cable
96-00 LS intake manifold gasket
96-00 EVAP purge solenoid
96-00 IAT sensor
B series header (99-00 si, 94-00 teg)
96-00 LS exhaust manifold gasket
MOUNTS:
99-00 si rear mount bracket
94-00 LS/GSR/Type R front trans mount bracket
96-00 CRV driver’s side front lower engine mount bracket
99-00 si timing belt bracket (possibly, unsure)
ECU:
96-00 OBDII LS ecu p75
Transmission:
LS Hydraulic
LS trans mounting bolts
clutch fork
clutch fork pivot bolt
clutch fork release spring
Clutch:
99-00 si or LS/GSR/Type R
Any b series flywheel
94-00 Integra NON ABS axles/intermediate shaft
94-00 LS/GSR/Type R shift linkage + bolts/washers/bushings
Old Jan 1, 2010 | 09:39 PM
zfinatic's Avatar
hope that helps. bout to do the same thing on my ej with a few extras
Old Jan 1, 2010 | 09:41 PM
zfinatic's Avatar
if u need more info i have a few other threds saved in my favorites...
Old Jan 2, 2010 | 02:01 PM
alright cool man that definately helps out thanks a lot
Old Jan 2, 2010 | 05:07 PM
jayWknight's Avatar
Corrected information in ()
wiring harness (use your original harness, extend plugs. Because the civic's after 96 have a one piece harness)
crv alternator +2 mounting bolts (any 96-01 b-series integra or crv alternator)
94-00 ls starter + 2 mounting bolts(any b-series starter from 94-01 integra)
96-00 LS intake manifold- loaded (fuel rail, injectors, fpr, and evap purge solenoid)
96-00 LS throttle cable (94-01 integra ls throttle cable)
96-00 IAT sensor
96-00 LS exhaust manifold gasket (94-01 ls the same)
MOUNTS:
99-00 si rear mount bracket (94-01 b-series rear bracket ls/gs/gsr/typeR same or 99-00 si rear bracket) AKA: T-bracket
94-00 LS/GSR/Type R front trans mount bracket with bolts
96-00 CRV driver’s side front lower engine mount bracket (only if you want to maintain A/C, otherwise, any 94-01 integra or 99-00 si bracket will work)
99-00 si timing belt bracket (keep the bracket that comes with the engine, will bolt directly to your factory mount)
ECU:
96-99 OBDII LS ecu p75 (00-01 integra ls ecus have immbolizers)
Transmission:
LS Hydraulic (any b-series hydro transmission bolt will work)
LS trans mounting bolts (any b-series, shares the same bolts)
clutch fork
Clutch:
99-00 si or LS/GSR/Type R (any dohc b-series clutch from 94-01 integra, 93-97 dohc vtec del-sol, and 99-00 si)
94-00 Integra NON ABS axles/intermediate shaft (ABS axles works fine)
missed parts and tips
-99-00 si intake box to pass bar
-exhaust system will be modified in order to for the header to bolt in place.
Old Jan 2, 2010 | 06:33 PM
DVDr's Avatar
Definilty good information, my 2 cents.
If your going from D series to B series its harder/hassle/expensive to jump into a b20 setup.
Try and find a full b18b setup swap that in your car a year down the road when you get bored swap out the b18 and swap in the b20 and get a chipped ecu .
Old Jan 3, 2010 | 08:37 AM
can i just use b-series mounts all together?
Hondarookie93
25
Nov 3, 2010 05:52 PM
Hondarookie93
Oct 31, 2010 12:20 PM
IIXtremeHansen
Texas -OK -LA (Sales)
May 4, 2009 06:04 AM
97civic123
Sep 30, 2006 11:18 AM
