gsr swap into dc harnes question
im swaping a obd1 gsr motor into my 94 integra ls chasis. how do i go about doing this with my stock wiring harness? thanks
Re: gsr swap into dc harnes question
Just pin in the IAB, Knock sensor, VTEC pressure switch and solenoid wires. If you want to be totally stock about it, run them to the strut tower plugs so it's just like factory.
can you elaborate about that a little better? i run them to the strut tower plugs and then it is ready to go?
You have to see if there is something on the body side of the strut plug. If there is not, you need to run from the body side to the ECU.
GSR eg94
03-15-2009 09:05 PM
