HELP h2d with h23a in ej2
Old Oct 22, 2009 | 08:59 PM
mooze's Avatar
Default HELP h2d with h23a in ej2
so im doing a h2d with a p20 and a h23a vtec. the problem in encountering right now is getting the tranny and motor to bolt up to the chassis. nothing lines up correctly. seems as though the tranny is to far to the passenger side. all help would be appreciated thanx in advance.
Old Oct 22, 2009 | 09:00 PM
mooze's Avatar
Default Re: HELP h2d with h23a in ej2
Old Oct 28, 2009 | 04:12 PM
hisnibs's Avatar
Have you tried removing the crank pulley to see if that will give you enough clearance to bolt up the tranny?
Are you using a Balance Shaft eliminator kit?
mooze
Oct 23, 2009 11:03 AM
KDvtec5757
Aug 18, 2008 06:58 PM
93sihatchy
May 26, 2007 06:03 PM
hatchback_al
Feb 12, 2004 10:30 PM
Boosted-Ek
Sep 13, 2003 06:24 PM
