H issues out of nowhere!!
Old Nov 23, 2009 | 08:21 PM
H22EG'z's Avatar
Default H issues out of nowhere!!
hey guys, i recently swapped an h22a1 into my 92 civic dx and this last weekend i had a few issues. Ill say the major issue was that when i turned the car on it idled well as usual, i allowed it to warm propperly and backed up and when i went into first and began to apply the gas it started to sputter and my lights were dimming.. and the car was droppin the idle to about 4-500rpm. I called a buddy and he told me to check the plugs.. reset the ecu and see what happened.. the Plugs looked like they had some condensation in them a slight bit at that.. and when i reset it worked... Im jus lookin for some help as to why this may have happened, ty hope my ignorance doesnt drive anyone crazy
Old Nov 23, 2009 | 09:11 PM
BigBlock22's Avatar
Default Re: H issues out of nowhere!!
so are you saying you no longer have the problem? if the lights were dimming that could be a sign of the alternator not working properly. at the same time you will typically get a electrical load detector CEL if this problem occurs. hows the car drive now?
Old Nov 24, 2009 | 06:32 PM
H22EG'z's Avatar
it drives now.. so i dunno if it ground out on something or some ****.. iono, and yea i thought it was the alternator as well.. as far as the CEL ill still have that till i get a P28.
Old Nov 24, 2009 | 06:38 PM
bar'dh22's Avatar
loose alternator connection
Old Nov 26, 2009 | 07:29 AM
ESP.net's Avatar
Check Alternator, then Battery, sounds like what happened in my H22 DC this past week. Didn't want to idle, recoil was bad, wanted to stall, when a load was on it, headlights etc/heater wanted to stall...
Check the TPS .5 at closed 4.5 at WOT. Get it as close as you can. Simply take the voltmeter stick a needle in the middle wire of the TPS on back side and slide it in till it makes contact with the pin, then hook it up and voltmeter it.
I personally also had to adjust the throttle lever stoppage screw on the throttle body to get it up a turn or two. Solved my issue.
Old Nov 26, 2009 | 09:06 AM
H22EG'z's Avatar
ah.. aight, i had to deal with this at like 1am on the freeway cause it stalled my car too. ill check all those things.. i also looked on my ecu wires, and one of them broke so.. il have to fix that too..
Old Nov 26, 2009 | 09:18 AM
H22EG'z's Avatar
{Check Alternator, then Battery, sounds like what happened in my H22 DC this past week. Didn't want to idle, recoil was bad, wanted to stall, when a load was on it, headlights etc/heater wanted to stall... }
thats exactly what was happening.. ill check that stuff out ty for the reply
citizen21
Dec 9, 2010 08:32 PM
G0TB00ST
Feb 21, 2009 10:48 AM
96WhiteOnBlack
Jul 12, 2007 08:50 PM
Osek206
Nov 10, 2004 12:19 PM
dragtaccord
Nov 8, 2002 01:41 PM
