H2B alternator bracket (Ef chassis)
Old Nov 1, 2009 | 11:35 AM
juan3023's Avatar
Default H2B alternator bracket (Ef chassis)
I have a really quick question for all my fellow H2b'ers Well I plan on buying a alternator kit since I have a h2b in my 1991 honda crx my question is can you please give me your personal opinon or advice on wich one will work better (I am not useing Balance shafts removed Kaizenspeed kit) on EF chassis
Old Nov 1, 2009 | 10:24 PM
juan3023's Avatar
Default Re: H2B alternator bracket (Ef chassis)
Any opinions and I also forgot to mention that I plan on useing a d series alternator
Old Nov 2, 2009 | 09:43 AM
juan3023's Avatar
Old Nov 2, 2009 | 01:15 PM
ESP.net's Avatar
Your going to want to run our ESP Upper D or H 1/2" over alternator kit. Removing the balance shafts/pulley is a must, this will move the crank pulley 1/2" over towards passenger side. Run the KS spacer on the outside of pulley or a modified OEM pulley as the spacer.
You will then need to not run the timing belt plastic or notch in route of alternator belt.
2 things to consider purchasing:
ESP EF H22/F Traction Bar System
Old Nov 2, 2009 | 06:12 PM
NABeastRR's Avatar
half inch over plus no balance shaft is a must...id go with the D alt just for a lil more clearance.
Old Nov 6, 2009 | 10:53 AM
88ED8's Avatar
Originally Posted by NABeastRR
I'd go with the D alt just for a lil more clearance.
X2
Old Nov 6, 2009 | 05:25 PM
NABeastRR's Avatar
oh btw use 88-91 D alt. its diffrent & thats what there kit was built around or it was when i bought mine.
Old Dec 19, 2009 | 11:17 AM
juan3023's Avatar
Originally Posted by 88ED8
X2
yes I am going to use a D series alternator thank you very much for the help guy's
Old Dec 19, 2009 | 11:25 AM
juan3023's Avatar
I have a quick question so if I buy the kaizen speed balance shaft eliminator kit& (Ecplicit speed performance) h22 alternator tensioner kit I should be good with the clearance right ???
Max500
Jan 5, 2012 12:54 AM
95EG2
Mar 14, 2011 06:44 PM
tigueremalo
Jan 13, 2007 03:19 PM
Jet Black
Aug 21, 2005 05:55 PM
EKCivicR
Mar 28, 2004 05:58 PM
