first acura Ls-vtec
first acura Ls-vtec
this is my first acura integra and opt. for ls vtec /boosted the swap was nice but im running in to some stuff. do i need a gsr oil pump or water pump . and what C/R should i run if boosted I found a kit on line
(4) Eagle H Beam Rods
(4) JE/SRP Pistons-Wrist Pins and Locks
(1) Complete Set of JE File Fit Rings
(1) Eagle 4340 Forged Steel Racing Crankshaft
Full Set of Main and Rod Bearings
Assembly Lube.
the head is fully built and tranny is set up nice could i get a lil more help . im a noob ...in the honda world ...
Assembly Lube.
Re: first acura Ls-vtec
You don't need an after market crankshaft. You are better off using OEm bearings. A good compression ratio for a turbo Honda is around 9.5:1. Just read around in the Forced Induction forum to get more ideas.
I WANT TO CHANGE THE CRANK I SPUN THE ROD BER. AND I WANT TO TRY TO MAKE 500-600Hp THE CARS GOT 200,000 + MILES on it ...
It's up to you what injectors you run.
You need to visit the Forced Induction forum and do some research. Nobody is going to spoon feed you everything.
dont waste cash on crank the stock crank can handle crazy numembers of hp just go for all good parts type r oil and water pump acl race bearings arp head studs
go on google type in ls vtec a guy has a great write up
95, acura, bearings, compression, crankshaft, horsepower, integra, ls, lsvtec, main, make, rod, tapa, vtec, yahoo
