f22a6 head on f22b2 block?
Re: f22a6 head on f22b2 block?
i havn't tried that specific combo yet, but i know those two motors are similar looking, and i know that the F22A6 head fits the F23A1 block with no modifications. VTEC and non-VTEC F-series have different length timing belts, but you're comparing non- with non- so it should be the same. i would recommend comparing the head gaskets and determining if there is any significant difference or need to use one instead of the other.
something different
1 Post
they bolt right on, i did it last year. no mods needed.
i used an f22a1 timing belt/tensioner, etc and it worked fine. i used the same setup on an f23 vtec bottom end.
easy peasy.
easy peasy.
