eg f22 mounts
Old 01-30-2010, 09:16 PM
adam00's Avatar
Default eg f22 mounts
What are the best mounts for the price to fit a jdm dohc f22b in to a 95 civic dx coupe? Hasport, Avid, innovate, hcp ect... also what do i need to do to wire up the the motor to the car, could i use a civic dx harness and delete the iabs?
Old 01-31-2010, 03:19 PM
adam00's Avatar
Default Re: eg f22 mounts
No one has tried these mounts?
Old 02-05-2010, 12:54 PM
adam00's Avatar
Which wiring harness do i use?
Old 02-27-2010, 11:49 AM
adam00's Avatar
Bump i need some help
Old 02-27-2010, 12:08 PM
Big Cat
fatboy1185's Avatar
Any mounts that will work for a H22 in your chassis will work for the f22b
Old 03-01-2010, 06:19 PM
ehulst's Avatar
heres my build link...http://cb7tuner.com/vbb/showthread.php?t=73927..it was an SOHC swap..i used the factory Ex VTEC harness..p28 ECU....hopefully thatll help you...had to re-drill the trans mount to work....
Old 03-02-2010, 07:46 AM
HAMOTORSPORTS's Avatar
You will use any 92-95 civic EG H22 mount kit: Hasport EGH2, or Innovative B29550
The axles I beleive will be the same axles that go with the corresponding mount kit...(you may want to double check here though, the accord intermediate shaft I think is different than the prelude)
Best of Luck!
wullie_vtec
09-06-2006 10:50 PM
JDMbiAtcH
08-30-2005 12:14 AM
EM2Civic
04-13-2004 10:19 AM
Rukusmasta2
09-01-2003 01:46 AM
TEALmobile
01-30-2003 01:03 PM
Quick Reply: eg f22 mounts
