2 Head Gaskets?? High Compression?
Old Dec 27, 2009 | 03:05 PM
uses0ap's Avatar
Default 2 Head Gaskets?? High Compression?
does anyone know which layers to use on a head gasket to make a 5 layer? LS block with ITR head and CTR pistons.
thanks
Old Dec 28, 2009 | 03:57 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: 2 Head Gaskets?? High Compression?
whoa. wha?
using multiple gaskets? wow. i dont have an answer for you on that but i must say, im scared for you if you want to use 2 gaskets.
i got an enginge from a kid, and the guy that "built it" for him said he did lower the compression. it was a b16 block, ls crank and rods (yeah) and 5 stock head gaskets. the kid got hosed.
Old Dec 28, 2009 | 11:44 PM
king06's Avatar
LOL at the 5 gaskets.
If the point of using two gaskets to lower compression than you might wanna go with Comedic.
You should just run e85.
Old Dec 29, 2009 | 03:11 AM
jr_deleon's Avatar
Why in the world do you want to do that? The title is decieving, but whether it is you or a suggestion from someone else it is a bad idea. Its almost a joke to see this posted becuase it doesnt seem well thought out. the title should at least say "2 head gaskets?? Lower compression?"
if thats what you wanted to do, then look up Cometic, not 2 stock head gaskets
Old Dec 31, 2009 | 05:56 PM
DSRxCandyh2bEG's Avatar
2 headgaskets= bad idea
a cometic head gasket will be a much better option.
Old Jan 3, 2010 | 06:42 PM
GregZilla17's Avatar
New User
dont do it!
Old Jan 4, 2010 | 01:34 PM
akurtzer57's Avatar
If you want to lower compression. With head gaskets which is pointless and way expensive. You could get custom gaskets made you whatever thickness you need.
ProjectBB6
Mar 13, 2008 09:24 AM
Ivan_JDM_hatch
12
Jul 13, 2007 06:44 PM
rmcdaniels
Nov 23, 2005 11:45 AM
tegasaurus
Dec 23, 2003 02:54 PM
p1ccoloz
Apr 21, 2003 09:41 AM
