evolution h2b kit question...
Old Jan 24, 2010 | 12:37 AM
allmotorg23ef's Avatar
New User
Default evolution h2b kit question...
i recently purchased a h2b evolution kit for a EG chassis application from a friend for a decent price only problem is i have a EF chassis does any one know what do i need to get to make this work i am also using a cable actuated lsd b16 transmission, i am also concerned since i am doing a g23 swap would the driver side bracket that goes on the block be different on a F series block application? all help is appreciated thanx guys...
Old Jan 24, 2010 | 03:16 AM
jakefalcons's Avatar
Default Re: evolution h2b kit question...
Hi not sure how to the kit works for different chassis. I'm also doing a g23 swap. I'm using the qsd kit though and drivers side engine mount adapter plate fit the f23a, but only 2 of the bolts were able to fit out of the 4 holes otherwise its fine.
Old Jan 24, 2010 | 04:39 AM
NAH2B's Avatar
you need the evolution ef mounts
might have to buy the whole h2b kit from evolution, not sure if they sell the mounts seperate.
Old Jan 24, 2010 | 06:09 AM
New User
thanx a friend of mines has an evolution kit and used hasport b series mounts and they fit fine
Old Jan 24, 2010 | 06:10 AM
New User
so only 2 out of the 4 holes bolt on? that doesnt sound to safe might have to get that adapter plate fabricated
Old Jan 25, 2010 | 12:12 PM
zbra09's Avatar
i believe all you need is b series mounts for an ef or http://www.evoindusa.com/ and go to h2b adaptor kit and they have just mounts
Nickb257
Jan 29, 2012 04:58 PM
rexracer626
Jul 9, 2009 05:55 AM
RobbieG35
Oct 7, 2003 08:39 PM
EVOCELICA
11
May 12, 2002 08:16 AM
