F2D 4wd is it possible?
Old Nov 22, 2009 | 05:27 PM
eklum's Avatar
Default F2D 4wd is it possible?
ive been told its not possible and it was possible.
apparently you have to grind down part of the F block to fit the drive shafts in a normal F2D swap why cant you do it at all if you had the 4wd system?
Old Nov 23, 2009 | 07:52 AM
hondamark35's Avatar
Default Re: F2D 4wd is it possible?
with the F2D you're right, it's neccessary to cut part of the block away just to fit regular axles in the FWD configuration.
i'm not real familliar with the 4wd tranxaxles but as i understand the case extends past the bell housing along side the block. i can only assume this takes up more room than the inner CV joint. that said it's likely there just isn't enough block material left to clearance for it.
unfortunately i don't have a 4wd case handy, otherwise i would fit it up to the adapter plate and block and see how impossible it is... it seems the 4wd cases are as rare as guys doing F2D.
Old Nov 23, 2009 | 06:24 PM
RallySol's Avatar
You'd use a half shaft with the 4wd tranny and if the half shaft is about even with where the oil pan meets the F block you might be alright.
Old May 18, 2010 | 11:36 PM
eklum's Avatar
sorry for the late response!
thanks i watched you build your car online and it really inspired me! im gunna try to get my hands on a spare tranny and f22 block and eventually an adapter plate.. ill def. keep you posted should see updates by june if any ones got ne thing to contribute chime in thanks!
OXY95LSSC
Northern California (Sales)
Dec 20, 2011 04:27 PM
Nextelbuddy
Feb 11, 2004 05:38 PM
JediPimpCrx
Mar 25, 2003 06:48 PM
