How much does a H22 CRX weigh?
Hi all, I am wondering if anyone knows the weight of a H22 CRX? I am hoping it is under a tonne (1000kg).
Thanks in advance
Thanks in advance
Re: How much does a H22 CRX weigh?
All depends on the year and model you have...
My 90 Crx HF MT 1967 lbs I took mine to be weighed in a few years ago
JDM H22 Crx 2200 lbs with me in it, minus my weight at the time 180 lbs = 2020 without driver
So take the 2020 lbs - 1967 lbs + 53 lb difference ... No weigh reduction was done except getting rid of the rear pastic side panels and middle plastic in the rear probably 10 lbs there...
Some equipment was lighter then stock such as our ESP Traction Bar System vs stock cross member etc etc.
In theory if you have ESP EF H22A Products take the weight of your car and add 50-70 lbs.
4g4drb17
05-12-2004 08:21 AM
