B16 B Civic Type R?
New User
B16 B Civic Type R?
Hi I currently have a 6th gen sir 2 jdm motor in my car and was thinking of trading it in and upgrading to a b16b motor. Would it pretty much just bolt in? Would I need to rewire, replace ecu or anything else? I could keep my tranny correct? Its the hydro one.
Moderator
Re: B16 B Civic Type R? (civicL)
b16b same as b16a....cept more power....you will want a new ecu...but wiring an all is the same....i have only seen one b16b in my life.....i got a hardon
New User
Re: B16 B Civic Type R? (chad)
Would I need a short block or a long block then? Would the short block have all the neccessary components(I know sometimes they are missing the camshafts, which I need). Do they even sell the b16b's like that, in short block form? Please help anyone. Thanks.
New User
like chad said b16a is the same as a b16b,why dont you just get high compression pistons and cams and it should be close to a b16b. Its like tryin to make a gsr to a type R
CTR motors are expensive as hell. Unless you want the exclusivity of having the CTR engine, bet a B18C1 from a GSR. It would have a little less HP, but it would cost a lot less money. You could modify the B18C with the leftover money modify it and make more powerful and have more torque.
Re: B16 B Civic Type R? (FSTASNTZ)
The b16B is actually a destroked B18C5. Yes, a destroked ITR motor.
Jason
Jason
spencedogg
04-14-2003 08:23 PM
