Cheap man's ITR?
Old Nov 7, 2001 | 07:57 PM
IcyDC5's Avatar
Default Cheap man's ITR?
Hi,
I have a few questions regarding performance with a B16A head paired with an ITR block. I'm hoping someone here would be able to help me.
If I were to purchase an ITR block, what other parts would be necessary to obtain performance similar to a USDM ITR? And approximately how much would this cost me?
Thanks for any replies in advance.
Old Nov 8, 2001 | 11:14 AM
Trey's Avatar
25 Year Member
Default Re: Cheap man's ITR? (NeoBuRST2K1)
JDM ITR pistons w/ rings-$350
CTR cams-$500
ITR valve springs-$???
Skunk2 intake-$380
JDM ITR ecu-$350-400
JDM ITR header-$450
2.5" carsound cat-$???
ITR crank-$750 (not needed but nice)
That should get ya going....
Old Nov 8, 2001 | 02:32 PM
Turbo_Teg's Avatar
New User
why go itr block ,just go gsr with a b16 head (referred to as the poorman's type R)and build it to beat a itr motor. get pistons,valuetrain and someperformance cams and sprockets.
Old Nov 8, 2001 | 06:05 PM
IcyDC5's Avatar
Default Re: Cheap man's ITR? (Turbo_Teg)
About how much would a new GSR block run me? And how far off, performance wise is a GSR block from an ITR block?
Thanks.
[Modified by NeoBuRST2K1, 7:06 PM 11/8/2001]
Old Nov 10, 2001 | 05:48 PM
bojangs's Avatar
New User
prolly about a grand.. depends what kinda deals you can find really..
gsr's are rated 170hp, itr 195hp..
if you want to run with other itr hybrid's follows trey's plan except for a couple things..
-keep your gsr crank- that'll be fine
-if using a b16 head don't waste money on a skunk2 intake mani, just get an itr
-jdm itr ecu? $350-400!?! sheesh.. what a waste.. get a custom chip or fuel controller instead..
my $.02
Old Nov 10, 2001 | 06:23 PM
DR. ON POINT's Avatar
Banned
Default Re: Cheap man's ITR? (bojangs)
looks like u just want something thats fun to drive. Just pick up a bare b16 block, I think they go for 100 bucks or so now and get the works done to it. If u want to buy a block thats already built I hear L Natural is selling them. Suposedly 2.0 b16's for $2000. I dont know the web site.
Old Nov 11, 2001 | 10:22 AM
xJ.SLOTHx's Avatar
Default Re: Cheap man's ITR? (On Point)
http://www.l-natural.com
i believe
Old Nov 11, 2001 | 01:54 PM
Yellow Dragon's Avatar
Correct me if I'm wrong, but I always thought the Poor Man's ITR engine is an LS block mated to a B16A head with ITR cams.
Old Nov 11, 2001 | 03:30 PM
Banned
Default Re: Cheap man's ITR? (Yellow Dragon)
a poo man' type r engine is a gsr block filled with integra type r stuff with a type r head
Old Nov 12, 2001 | 08:42 AM
Gong Show's Avatar
itr block(bare)
b16 head
ctr or better cams(jun,toda,spoon,skunk2)cam gears
jdm 4-1 or better header(above)plus 2.5 cat
jdm ctr or itr pistons(depending on the comp you want)
v-afc&chipped ecu
stock t-body bored to 64(at least)
a clutch,flywheel, and lsd(help get all your power to the ground)
and lots of tuning...
a gsr head will raise the compression more than a stock pee16 head... but if you get some headwork and valvetrain done to a pee16 head then you will come out to having a real type-r... i like gsr heads since they help raise compression because of the shape of the chambers, but most peeps think pee16 heads are better... the choice is yours... im sure im forgetting some parts, its to early for me to think right now... im helping to of my friends put together a a list for poorman's they want to build... if you want to email me up, i can find a list of stuff to help you choose from... http://www.addictjpratt@hotmail.com
Old Nov 12, 2001 | 09:02 AM
Banned
Default Re: Cheap man's ITR? (LS(litesleeper))
just buy a real type r motor...less of a hedache...u can get them fo 5500
mr_munro
Feb 24, 2011 02:24 PM
mr__orange97
Jun 10, 2006 11:19 AM
doobiesack23
Mar 24, 2004 03:53 PM
ace1875
Feb 15, 2003 09:26 PM
Todd00
59
Jun 22, 2001 11:14 AM
