Rear brake lights stay on...keeps killing battery
So this is another one of my engine swap problems....
Background: had an accident...got the had engine swapped along with the tranny (auto to manual)
Every time I park my car, the rear brake lamps stay on. If I pull on the brake pedal with my foot it goes off for a sec then after it settles it goes back on after it settles. Basically it seems like it is set way over sensitive. Can anyone help?
(remember I had an automatic with two pedals...now it's got three...if that makes a difference)
Re: Rear brake lights stay on...keeps killing battery (chikai)
Sounds like you have a problem with your brake switch. Check under your dash by your pedal assembly. It probably just needs adjustment.
Kalokohan
07-14-2006 10:50 AM
