setting timing on LS/VTEC???
Old Oct 24, 2001 | 09:51 PM
ysrhatch's Avatar
New User
Default setting timing on LS/VTEC???
i have a problem on setting my timing on this ride. please i need a little assistant. well heres my problem. i set the arrows on the cam gear straight up and then put the crank pulley in position where the red mark is line up with the line on the cover rite. then tighten up the tension is that all. or am i missing something. please help.
Old Oct 25, 2001 | 06:59 AM
topspeed86's Avatar
Default Re: setting timing on LS/VTEC??? (ls_vtecer)
Make sure that the marks on the cam gears are straight across, Then make sure the white mark on the pulley is matched up with the timing cover you should have no problem.
Old Oct 25, 2001 | 07:16 AM
ysrhatch's Avatar
New User
Default Re: setting timing on LS/VTEC??? (topspeed86)
you mean the arrows point together right in the middle or straight up? and plus on my crank pully there is no white mark only a red one. which is which.
d16trex
Aug 23, 2010 03:03 AM
rrmorseb18c
Apr 16, 2008 11:36 PM
4gencivicef9
Jun 14, 2007 06:27 PM
Kirt Porter
Oct 8, 2004 09:10 PM
blue owns you
Apr 8, 2004 09:42 PM
