2.0 stroker kit for 1.8 ls
New User
im lookin to do a stroker kit for an ls block with b16 head. and was wondering
which pistons and rods to use.
any help would be nice
has anyone done this swap in a delsol?
if so what kinda times can i look for
Banned
Re: 2.0 stroker kit for 1.8 ls (phatsol)
ohh i know exactly waht u want...a b20, check out http://www.sohfast.com
New User
Re: 2.0 stroker kit for 1.8 ls (On Point)
i want to know what it will take to stroke a 1.8 ls block to a 2.0 and what rods and pistons to use
can anyone help me
can anyone help me
hey dont spen all that money just bore it and sleeve it. But even thats kinda expensive just get a b20 block. If you stroke a b16a to a 2.0 you will have a horrible r/s ratio and wont be able to rev that high At all.
Re: 2.0 stroker kit for 1.8 ls (B18CivicHB)
Dont stroke it! That will give even worse R/S ratio then it already has.
Id resleeve the block to 85mm and use some JE B20 pistons
New User
Re: 2.0 stroker kit for 1.8 ls (Turbo_Teg)
the ls and b20 use the same rods, just that the ls has a 81mm bore (piston) and the b20 has a 84mm bore(piston). so u dont need a stroker kit from crower...just bore and resleeve the ls block to 84mm and get 84mm sized pistons and u will have a 2.0 vtec with the b16 head mounted on top. or like hx guy say u can bore it to 85mm and get 85mm pistons and u will have a ls with a bit more displacement then a stock b20vtec.
