Compression Test on motor out of the car??
New User
Re: Compression Test on motor out of the car?? (On Point)
Can't ya do it by sticking it in the sparkplug hole and turning the crank over by hand..Not sure exactly
New User
Just like you would if it were in the car.....
Need to have the starter on the motor and a battery handy. Hook up the battery and energize the trigger wire of the starter motor.
Re: Compression Test on motor out of the car?? (mingchi96)
Who said you have to spin the motor fast? Compression still builds up even when you turn the motor by hand (slow)
New User
Re: Compression Test on motor out of the car?? (HX_Guy)
you will need to have the starter and the trans, just run power to the starter so it turns. Remember the motor will be cool so the numbers will not be 100% also you will need to hold the throttle body open by hand while you have the motor cranking
blackeg
09-22-2004 10:57 AM
Sinner
07-12-2003 05:54 PM
