Does HASport B series into 88-91 kit use a 90-93 Integra rear mount?
Just wondering before I start a guy's swap. Never used the HASport kit before.
New User
Re: Does HASport B series into 88-91 kit use a 90-93 Integra rear mount? (Jared)
yep they all use that l bracket of a 90-93 integra, I found this out the hard way, in the middle of the swap. Also once you have that rear mount tight put some thread locker on it so it won't come loose on ya.
Re: Does HASport B series into 88-91 kit use a 90-93 Integra rear mount? (wuhungsixxx)
how about the driver side ????90-93 integra also for 88-91 civic?
Re: Does HASport B series into 88-91 kit use a 90-93 Integra rear mount? (Json79)
If you're referring to the mount that actually bolts to the block, then that is 90-93 teg as well.
BlueShadow
06-22-2004 06:04 PM
theturbocivic
11-22-2002 05:26 PM
Jared
10-24-2001 05:49 PM
