What's needed to make 92-95 Civic Shocks fit 89-91 Civic?
I said I don't want a title!
I have a brand new set of Tokico Adjustables for my 93 Civic, but I really want to use them on my 91 instead. Can this be done, or is it about impossible? Actually, I have an entire Ground Control setup for the 93 that I want to use, but I'm not worried about the perches or springs fitting because I know they will.
Thanks.
Thanks.
Re: What's needed to make 92-95 Civic Shocks fit 89-91 Civic? (Todd00)
All U need is the Front Forks that hold the shock to the front lower control arm cause the Shock is bigger at the bottom from the 92 up so just get that and it will work perfect.
New User
i asked this same question a lil while ago cuz i wanted to do the same thing to my crx...changing the forks is needed and will work...however some people where also saying it might raise the front of your car also...however i never got a definite answer...anyone know for sure...?????
Re: What's needed to make 92-95 Civic Shocks fit 89-91 Civic? (wuhungsixxx)
I guess one could always measure the shock and fork in the front to know for sure.
Also, the rear shocks from a 92-95 will fit the 88-91 rear just fine? I assume that they will, but just wanted to check. Thanks.
Re: What's needed to make 92-95 Civic Shocks fit 89-91 Civic? (Jared)
How much will it raise the car? .5", 3"? A little height raise isn't too bad, but a large one would suck.
Re: What's needed to make 92-95 Civic Shocks fit 89-91 Civic? (vteccivicsi92)
Yeah, it will raise the front a bit and it will look like you got bricks in the trunk.
scdarksol
14
01-15-2021 09:55 AM
si0385.
06-18-2006 06:27 AM
mahin
09-13-2005 01:17 PM
TheIntegraGuy
01-17-2005 08:04 AM
