Which is better a P28 ECU or a switch over harness for ODB2 B18c1 to 92 EG?
I got a b18c1 with an ODB 2 ECU. It is going into my 92 EG DX. I am kind of confuse of the wiring. I did a search and found some information stating that you need an ODB 1 (p28) ecu off a civic Si, while others say you can get a switch-over harness. Are both routes correct? What are some of the advantages or disadvantages of one over another? I can find an P28 cheaper than the switch over harness, and possibly even chip it for future mods, but I dont' wanna take the risk of buying a nonfunction ECU off the web
1 Post
Re: Which is better a P28 ECU or a switch over harness for ODB2 B18c1 to 92 EG? (karmannghia)
if you run a P28 on a GSR motor you lose alot of torque due to the dual butterflies that GSR motor has. P28s are only meant for single butterfly setups like that of the B16 and Type R motor.
Get a skunk2 manifold and it'll be fine to run a p28. Single butterfly.
Stay OBD 1
Stay OBD 1
Re: Which is better a P28 ECU or a switch over harness for ODB2 B18c1 to 92 EG? (Guardson3r3)
Will the GSR odb 1 Ecu needs a switchover harness or will it plug into my existing 92 EG DX wires?
1 Post
It'll plug right in.
All obd 1 harnesses plug into obd 1 ecus
the same goes for every other obd.
New User
Re: Which is better a P28 ECU or a switch over harness for ODB2 B18c1 to 92 EG? (DragonCTR69)
well if he already HAS a p28 ecu it'll be cheaper to have it chipped than buy a new ecu.. and the chipping is $150 for any program you want.. talk to katman or locash.. they're prices are identical. plus, you'll have much more aggressive fuel/timing maps for half the cost of a gsr ecu.. i say stick with the p28 unless you find another CHEAP obd1 ecu..
1 Post
Re: Which is better a P28 ECU or a switch over harness for ODB2 B18c1 to 92 EG? (bojangs)
yeah, but if he has a gsr motor sans a skunk2 manifold, the results of having a chipped p28 will be less than that of a obd 1 p72.
No control of the secondary butterflies nets a loss of like 10ft/lbs of torque.
but, you could buy a skunk2 manifold and be done with it.
Re: Which is better a P28 ECU or a switch over harness for ODB2 B18c1 to 92 EG? (fowler)
Will I have to switch the distributor to a ODB 1 type too? Or would my existing one work, which came from a 99 GSR engine
Location: Toronto, Canada currently residing in ATL, GA, USA
What year is the motr because the ECU may still throw a code. I got that jumper harness (OBD1 to OBD2). I think you e-mailed me. I use my P28 ECU (Rechipped by Kenji to run the motor now. Besides an idle problem the car runs fine (That and my transmission is a big ? as to what kind gearing I have).
Re: Which is better a P28 ECU or a switch over harness for ODB2 B18c1 to 92 EG? (Apex i ITR)
bone stock 99 gsr USDM engine. trying to put that into a 92 DX EG. Yes, I think I emailed you about the harness. I am trying to figure out the best way to convert from ODB2 engine into a ODB1 car. I am seeing people doing it diferent ways. Which part of Atlanta are you in, I am in Norcross. I might need your help in the swap..
[Modified by karmannghia, 5:29 PM 11/13/2001]
I bought the whole set up (engine, ecu, tranny, mounts, shift linkage, ect..). Gonna try to put it in this weekend.
Thanks everyone for being helpful with my questions..
Did you get axles? Those are important. I have a testpipe I could sell you that bolts from the header to the exhaust until you get a calalytic converter custom exteded by a muffler shop.
You know, I need that too. It looks like I am digging myself a deeper hole from the moment I bought that 92 EG. It came with the axles...exhaust manifold. I was planning to drive that without the cat. or muffler to the shop and have them custom made cat. put on. Imagine what the neighbors will think when I pull that car out of the basement... I presume the test pipe will fit perfectly from the header to the cat back Apexi right? Because I got the Apexi cat back exhaust on it already. Who knows I might drive that around without the cat until my next inspection which won't be for another 11 months...
Sounds like we went down the same road. You call me @ 770-739-5934 if need any help or want to ask more questions about the jumper harness.
Why is the OBDI ecu so much better. If it just a daily driver and you really don't want to go all ***** out on it. I think you should just keep the OBDII ecu and get a jumper. Unless you can find a OBDI ecu, thats the hard part
