Can an LS crank fit into a b16 block?
Re: Can an LS crank fit into a b16 block? (myNAteq)
no, it just doesn't work...otherwise there would be no need for stroker kits....
...the problem is that if the rods are used then custom piston will be needed...otherwise contact will occur...
NOman0608
03-16-2008 06:57 PM
