zc Motor in '88 HF
zc Motor in '88 HF
I am in the process of getting a ZC (1.6 DOHC non-Vtec) motor and tranny from ARD Performance, but they don't supply ecu and wiring harness. Any info on what ones I need for this transplant would be greatly appreciated
Re: zc Motor in '88 HF (hfracing)
You can use the 88-91 si ecu, 89 integra ecu, or the jdm zc ecu. You don't need a wiring harness since you don't have to convert to mpfi since your car already runs 4 injectors. All you have to do is run two wires for the cam angle sensor since you now have two cams. Hope this helps.
It is good for a daily driver and not a bad car at the strip or track. It is worth the money because they are so cheap.
Try http://www.nippon-motors.com
they have them really cheap and they offer good reliable service.
Good Luck
Good Luck
New User
i say dont waste money on a zc,juss go with b series engine. much faster. With a zc you can hang with them, but dont you want to beat them not hang
"If you have the cash, turbo it"
