year of engine for swap?
Old Nov 6, 2001 | 08:39 AM
ckdelsol's Avatar
Default year of engine for swap?
i heard someplace that if you are doing an engine swap, you have to swap in an engine that is either the same year or newer than the year of your car. is this true? also, what year were B16A1's made and what years were B16A2's made? which is the better deal? B16A1 for like $1400 shipped? or B16A2 for $2500 shipped? any difference in power or anything?
Old Nov 6, 2001 | 09:04 AM
hvtec93's Avatar
New User
Default Re: year of engine for swap? (ckdelsol)
B16A1 FROM 89-91 HAS CABLE CLUTCH AND 160HP
B16A2 FROM 92-95 HAS HYDRALIC CLUTCH AND 170HP
Old Nov 9, 2001 | 01:06 PM
Armaan's Avatar
Default Re: year of engine for swap? (DragonCTR69)
Legit meaning smog legal, or if a cop pulls you over and checks the engine to find out it's from a older car? I am stuck in this situation right now. I have a fully built 2.0L Golden Eagle LS motor from a 1992 Integra ready for a chassis. I either want a 94+ Integra or a 96+ Civic. I just got my Clutchmasters Kevlar Multi-disc clutch today for a hydrdo trans, so I can't get anything from the 88-95 Civics or 90-93 Integras. Anybody????
Old Nov 9, 2001 | 01:12 PM
Spade's Avatar
Default Re: year of engine for swap? (2.0L Turbo)
convert the chasis to hydro.
Old Nov 10, 2001 | 08:30 AM
93civic_b18b1's Avatar
New User
your probably aware.....but make sure you remember that the shift linkage is going to need switched over to the 94-97 delsol DOHC VTEC shift linkage.....stock won't work. good luck w/ swap
Old Nov 25, 2001 | 05:00 PM
Suprdave's Avatar
The only difference in clutches is that 92+ are Large Spline and 89-91 are Small Spline. So if you get a 92-93 Cable Trans, it'll work fine with the Clutch.
Suprdave
Old Nov 25, 2001 | 05:04 PM
Suprdave's Avatar
Default Re: year of engine for swap? (hvtec93)
Your wrong...on like everything.
B16a1 have a 'Cable Transmission", but you dont' have to use one obviously.
All B16a are 160 Horsepower.
There weren't any USDM B16a made in 92.
B16A from 93-97 Del Sol VTEC
B16A from 99-00 Honda Civic SI
So if you want OBD1, It's gotta be 93-95 Del Sol VTEC
The Engines are basically Identical from 93-97 and 99-00.
Suprdave
strngblkman
May 26, 2011 03:08 PM
94_teggy_rs
Dec 17, 2007 08:07 PM
Dream_Seeker
Jan 11, 2005 04:09 PM
professorman
Oct 30, 2002 06:01 PM
civicmark
Jul 3, 2002 07:46 AM
