B16a/crx Axle problem..Help!
Messing w/ my car today and found my driver side wheel would'nt spin.Cecked everything out, seperated hub/axle to make sure the axle will turn on its own...and it does.Turns out when the spindle nut?(fat nut that holds the hub to the axles) is tightened neither the hub or the axle will move(in any direction)When nut is lose everything will spin.
I'm thinking I have the wrong axle on the car (too long),but im not sure.If anyone can share some ideas with me i'd really appreciate it.
My passenger side axle turned out to be the wrong,Thats whats leading me to think the same w/ the driver side
Thanks
Dan
Thanks
Dan
Re: B16a/crx Axle problem..Help! (Dank26)
Make sure that the metal ring spacer on the inside of the hub has been pryed out. Also that the black spacer on the end of the axle has been pryed off too.
New User
Re: B16a/crx Axle problem..Help! (pg_thao)
BlownHatch just solved your problem I had the same thing happen check out the link below it gives you all the info.
http://www.hasport.com/B16axles.htm
drjondurst
55
02-13-2003 09:38 AM
technine
11
12-20-2002 08:42 PM
takeheed
09-08-2002 02:32 PM
