odb2 to obb1
i just bought a jdm gsr odb2, he want to know wut parts and things you need to switch it to odb1. some one told me you need to switch the distributor and the alternator and all that other ****. wut do u need to make the swap to odb2 to odb1
First, what car are you putting this motor into? Answer that and I will be able to tell you how to do it.
Also, you don't need to switch the injectors and distributor. They are the same internally. The only difference are the plugs.
-kenji
-kenji
If you want to run the ECU that came with the GS-R swap it will need to be a '96-'99 JDM GS-R ECU. Otherwise you will need some sort of ECU conversion harness.
Drop the motor in the car. Modify your engine harness to fit the GS-R engine. Plug in the ECU.
-kenji
-kenji
My 2000 Civic EX is an OBD2-2, the reason I would like to convert is to make it easier to get Hondata.
If I have an OBD2-2 and I have a JDM B16a2 waiting to be installed, what do I need to do to convert to OBD1?
