GSR Tranny with B20B with Intermediate shaft? In 94 Civic CX HB
Re: GSR Tranny with B20B with Intermediate shaft? In 94 Civic CX HB (crxman00)
Any B-series intermediate shaft... all the same size.
FYI, on my turbo B20 setup (also GSR tranny), all I had laying around was an intermediate shaft and axles from a 90-93 Integra... they all work the same (B-series that is).
Re: GSR Tranny with B20B with Intermediate shaft? In 94 Civic CX HB (SLPR)
what is the int. shaft? is it inside the tranny, i asked this before but what the crapola is it? im getting my swap soon, how do i make sure im getting it.
Re: GSR Tranny with B20B with Intermediate shaft? In 94 Civic CX HB (g's hybrid)
Here let me assist
That is an intermeadiate shaft with a inner CV from an axel still attached to it.
[Modified by SLPR, 1:42 PM 7/16/2002]
speaking of int shafts, does anyone know of a trick to seperate the drive shaft from it? i could not separate it last time my motor came out so i just removed the as one piece but this time it has to because the drive shaft is damaged, anyone have any ideas, thanks
Re: GSR Tranny with B20B with Intermediate shaft? In 94 Civic CX HB (bikeboy80)
I simply aim my air hammer at the cv joint for the axle and squeeze. I was able to loosen them with a rubber mallet pounding it on everyside while turning it over and over until it came loose.
Re: GSR Tranny with B20B with Intermediate shaft? In 94 Civic CX HB (kinesistech)
also needed to mention -
'90-93 integra (b-series) int-shaft is male-female
-or the '90-93 axles are male on both ends (both side)
'94+integra (and del sol/civic si?) int-shaft is male-male
- the '94+ integra axles are male-male on the pass. side, and male/female
on the driver(intermediate) side...
when you run a '90-93 intermediate shaft, run axles from that year
when you do the '94+ run '94+ axles (I found that out the hard-way).
-l8r
-l8r
lance_ecl
10
07-02-2007 07:58 PM
shiftgear8000
05-27-2004 07:22 AM
Black R
09-10-2003 04:38 PM
