how can i do this? and will these work? help....
Old Jul 14, 2002 | 09:26 PM
turbo_ef9's Avatar
Default how can i do this? and will these work? help....
blown90hatch informed me that i could change the wires on my 01' itr distrib and make it a obd1? possible? how? and can i use the 01' obd2 injectors on the obd1 car? please help a fellow HT brotha out.. i spent most of my import life on the old B in the ef series and i'm lost:S thanks!!
Old Jul 14, 2002 | 11:33 PM
bryant's Avatar
Default Re: how can i do this? and will these work? help.... (b16_ef)
Here you are: http://www.jdmfan.com/technical/perf...obd1/index.inc
Old Jul 15, 2002 | 05:49 PM
doc's Avatar
doc
I've allready done with a 98 ITR distributor (OBD2). Just replace the connector on the distributor or on the harness. (Cut the wires and solder a OBD1 connector on.). The same game with the injectors, the connectors are different, so you just have to replace the connectors on the harness.
Christian
Old Jul 15, 2002 | 10:31 PM
turbo_ef9's Avatar
Default Re: how can i do this? and will these work? help.... (doc)
thanks bunches guys!!! you guys are great!!! thanks again..
jdmjin
Nov 26, 2017 08:59 PM
90civicgsr
Apr 8, 2008 07:23 PM
SuicideSlide
14
May 16, 2005 12:10 PM
civicsirplus
Aug 10, 2003 05:04 AM
