D16y8 92 CX
Old Jul 13, 2002 | 11:31 AM
madtownhonda's Avatar
Default D16y8 92 CX
So I have this crappy *** 92 CX (canadian made) and I have an old *** d16y8 just laying around. I'm going to put the engine into the car for lack of anything better to do with my time. I plan on using the stock harness because it is already wired for Vtec. Now I'm assuming that a P28 will plug into the harness but will all the other stuff work with this, like the dist, etc. Can I just use the CX mounts?
also, does anybody have the pinouts for a d16z6 ECU and a 92 CX harness?
Old Jul 13, 2002 | 02:00 PM
H22EK's Avatar
Default Re: D16y8 92 CX (madtownhonda)
you will need the trani mount off of the y8 and you will need the obd one injectors and dist.other than that i can not think of anything else you will need
Old Jul 13, 2002 | 02:40 PM
H22EK's Avatar
Default Re: D16y8 92 CX (H22EK)
and the alternator too, or you can just swap the plugs on all of those things instead, internals are the same
Silvertc
Aug 17, 2007 10:18 PM
traitorzxiong
Feb 16, 2005 10:30 AM
(Civic_Duty)
Oct 19, 2004 04:51 PM
Tw1n Turb0 Z
29
May 11, 2004 10:52 AM
icucnme
Feb 12, 2004 10:24 AM
