**95 JDM B18C1 head install: need bolt torque specs!**
i just put my friends JG pro series head, skunk2 im, skunk2 cams, and skunk 2 cam gears in his 93 hb........i need the torque specs for the:
head bolts
exhaust manifold bolts
intake manifold
cam journals
and any others that i will need from putting on the head.
and the sequence to tighten them!
thanks....i can usually get this stuff off autolibrary.org but it isnt working for some reason?!!
or are there any sites besides that one to get all the torque specs from?? thanks!
head bolts
intake manifold
cam journals
Re: **95 JDM B18C1 head install: need bolt torque specs!** (boostinb18)
head bolts:
1st step 22 ft-lbs
2nd step 60 ft-lbs
When looking at the head from the front of the car tighten in this order:
9 5 1 3 7
8 4 2 6 10
Cam caps:
20 ft-lbs. Start from the center four bolts and work your way out like this:
5 3 1 2 4
Each of these numbers represents four cam cap bolts.
I don't remember the specs on the intake and exhaust manifolds off the top of my head like the head and cam caps. But, I usually snug them up starting from the inside and working my way out.
-kenji
1st step 22 ft-lbs
2nd step 60 ft-lbs
9 5 1 3 7
8 4 2 6 10
Cam caps:
5 3 1 2 4
-kenji
