diffrences between 2nd gen & 3rd gen LS blocks ?
Old Jul 17, 2002 | 07:29 AM
nwarp's Avatar
Default diffrences between 2nd gen & 3rd gen LS blocks ?
i just picked up a 2nd gen LS block (b18a1) with pr3 (b16a1) pistons and was wondering if there was any diffrences between it and the 3rd gen LS blocks (b18b1) ?
Old Jul 17, 2002 | 01:16 PM
nwarp's Avatar
Default Re: diffrences between 2nd gen & 3rd gen LS blocks ? (NA DC2)
ttt, help me out guys
Old Jul 18, 2002 | 06:12 PM
vhd's Avatar
vhd
basically everything is the same except for the thermoswitch being on the back of the block for 90-93 and 94+ is on the thermostat housing, also the driver side mount bracket
Old Jul 19, 2002 | 04:49 AM
kinesistech's Avatar
Default Re: diffrences between 2nd gen & 3rd gen LS blocks ? (vhd)
There is an undrilled spot on the number 3 cylinder that can be drilled and tapped for a knock sensor, then you can use a gsr or b16 ecu. b18b doesnt have this.
Nickg116
Jul 26, 2006 12:01 PM
