How to add a wire or repin
Old Jul 13, 2002 | 11:58 AM
CRAYZBOYZS's Avatar
Default How to add a wire or repin
I have a 99 civic dx and is adding a 92 jdm b16a, I'm currently working on the wiring and I have to add the vtec and stuff but where can I find pins to add into the wire harness. Is there anywhere I can find a kit to pull and put wires into the wire harness. thanks
Old Jul 13, 2002 | 02:49 PM
memphiss13's Avatar
Default Re: How to add a wire or repin (CRAYZBOYZS)
i just used an old harness from the junkyard and took the pins from it. as for getting the pins out, its kind of tricky. there is a little plastic tab that you have to push and then the pin will pull out. you have to work with it a little bit, just use a small screw driver.
[Modified by rookie2nr, 5:51 PM 7/13/2002]
GReddy_Civic
Oct 18, 2009 10:21 AM
hitekper4mance
Oct 9, 2007 08:21 AM
9281hatch
Sep 11, 2006 12:18 PM
navin
14
Mar 10, 2003 12:16 AM
