crvtec-problems
Old Jul 19, 2002 | 12:17 PM
vaporz53's Avatar
Default crvtec-problems
Im using the 97b20 bottom end with b18c head. I dropped the compression to 9:1 and installed the block gurdle, but anyways..My problem is oil leaking from in between the head and block, where you plug the oil passage. Has anyone experienced this problem before??Does anyone know a possible solution to this. If I have to rip the head back off again Id like to know what to look for..
Thanks in advance
Jude Olwell
Old Jul 19, 2002 | 02:41 PM
Jeff C's Avatar
Default Re: crvtec-problems (vaporz53)
who did the conversion
was plug in the vtec oil supply hole sealed good
is the head possibly warped
Old Jul 21, 2002 | 09:52 PM
vaporz53's Avatar
Default Re: crvtec-problems (Jeff C)
see thats one of the things in question..I was wondering if somehow the plug could shift and leak..I dont think the head is wharped atleast i hope not
Old Jul 22, 2002 | 10:50 AM
BROOD's Avatar
Which head gasket are you using?
Old Jul 23, 2002 | 03:51 AM
kinesistech's Avatar
Default Re: crvtec-problems (SLPR)
A fact that I have never seen posted, and rarely tell anyone myself. Is that the stock gasket has copper rivets holding it together. The one near the oil hole on the head needs to be removed. It gets in between head and deck and doesnt seal all the way. Good luck.
Old Jul 23, 2002 | 03:56 AM
tinkerbell's Avatar
hey Jude!
(sorry!)
anyways - head bolts? which ones did you use/re-use?
hopefully the GSR/B18C ones?
t..
Old Jul 23, 2002 | 05:58 AM
Jeff C's Avatar
Default Re: crvtec-problems (kinesistech)
does this only apply when using the b18c head. i looked at mine with 1g b16 head and the rivets do not appear to be in the way.
gsr's because they are a little bit longer
Old Jul 23, 2002 | 07:25 AM
vaporz53's Avatar
Default Re: crvtec-problems (tinkerbell)
Im using the ARP head studs..The head gasket Im using is the CRV headgasket from a 97', I believe. Would that problem with the rivets apply to me??Will this headgasket work for my application?Any suggestions would be appriciated..These are some good ideas thus far. I need to get this oil leak fixed b4 I put my turbo kit back on!!Thanks guys for the help
Jude Olwell
Old Jul 23, 2002 | 08:13 AM
SuperSteve's Avatar
New User
25 Year Member
If you are using A GSR head on the CRV block, the oil leak may be caused by too much pressure build up in the crank case. When you use the GSR head and CRV bottom you eliminate the PCV valve and there is no venting for that pressure to vent out through. I ran into the same problem. I even had the internal VTEC oil line welded and shaved at a machine shop. What I did was drill a hole for a grommet on the valve cover. Then with a grommet in there i placed a PCV valve in the grommet and ran it into my Skunk 2 manifold. It doesn't totaly solve the problem but helps little.
-Steve-
Old Jul 23, 2002 | 10:36 AM
vaporz53's Avatar
Default Re: crvtec-problems (SuperSteve)
ya.. I did the same thing I tapped the valve cover and ran lines into a catch can with a breather..SO I think (hope) that is taking care of the head pressure...
Jude Olwell
Old Jul 24, 2002 | 09:33 AM
vaporz53's Avatar
ttt
the171
Feb 24, 2021 03:14 PM
Corksil
Apr 29, 2011 11:15 PM
DulinDragons
Oct 17, 2009 08:51 PM
stadanko
Jul 21, 2009 04:08 PM
shifts
Apr 6, 2007 02:33 PM
