Cluster swap-Gsr cluster into a 91 crx....
Yeah..it fits pretty good.Now how do i wire this sucka up?Anyone?Please?Someone help?Has anyone pulled this off?Can i use an 92-95 civic electronic speedo?Im still running a sohc.This is a tough one...i appreciate any help.I mostly just need the pinout listings.Thanks...
Mikey
Mikey
Re: Cluster swap-Gsr cluster into a 91 crx.... (CivicMikey)
this may not be a exact help, but you will get the idea,
Honda did a wise thing and kept colour codes fairly similar between models...
i swaped a 91 JDM teg dash into my 83 prelude without drama, make sure you use solder or VERY good conectors (if you can use the same pins - use a small pin to remove them and swap them over if you can!!)
here is a link to a dash pin outs:
http://b16a.honda-perf.org/cluster.html
this should help...
t..
this should help...
t..
Re: Cluster swap-Gsr cluster into a 91 crx.... (tinkerbell)
PS the CRX uses a mechanical VSS (Vehical Speed Sensor) and the ECU would be getting a signal out of the optical sensor located inside the actual speedo,
this will need to be factored into th eequation, what GSR dash is it?
t..
t..
Wowzers.Thanks alot for the input.Im actually only swapping the cluster out and its from a 98' Gsr.The car will soon be fully obd1 converted using a Blownhatch90 harness.Im planning on doing an electronic style speed sensor also...
Mikey
Mikey
JokerTypeR
02-03-2008 07:35 AM
JokerTypeR
12-27-2007 07:41 AM
STHPERFORMANCE
10-14-2003 01:44 PM
