88-91 hasport question?
Who has used the ef-b hasport bolt in kit? What do you guys do with the front motor mount bracket that is welded to the crossmember?
Has anybody experienced problems with the ft. crossmember motor mount bracket hitting or touching the block/transmission when racing or hard shifts since it only sits 1/4" away from the motor?
Re: 88-91 hasport question? (johnlsturbo)
I cut my front mount off. If you ever want to get a new header you will also have to modify the front crossmember so it is best to just cut it off unless you ever plan to go stock again.
Re: 88-91 hasport question? (meept)
I made cuts in certain places with a hacksaw so that I could pound it flat. I wasn't going to do anything with it until I tried to bring up the engine and the tranny was catching on it.
TearSDMF89dx
02-15-2012 02:52 PM
civbeater90
09-05-2002 10:10 AM
