B18C5 swap question, good question, not the like the rest of the B18C5 questions :)
We all know,
a complete swap comes with ECU, trans, axles etc etc
Can someone please put them in order of cost and I would aprreciate it if you can put an estimate on its part.
For example:
b18C5 motor=$3000
Trans=$1000
ECU=$700 etc etc
I might have found a motor like that and I woant to know how much extra I would need to pay for the rest and at which order I should be looking for a good deal.
Last question: Apart form the engine and transmissions, are the rest of the parts pretty easy to find?
thank you,
help me out and in a couple months I might be able to help you get one yourself
For example:
b18C5 motor=$3000
Trans=$1000
ECU=$700 etc etc
thank you,
Re: B18C5 swap question, good question, not the like the rest of the B18C5 questions :) (2 B 4GO10)
tranny 1000-1300 Higher though since there is a lot of demand.
Ecu - 200-250
Linkage 100
harness 150
mounts 100
then the rest for the long block, dist and sensors
Ecu - 200-250
Linkage 100
harness 150
mounts 100
