need help with a code 7 and 22
Old Aug 27, 2002 | 01:04 PM
311's Avatar
311
Default need help with a code 7 and 22
on a 91 integra with a freshly swapped b16. throttle angle and vtec system malfunction. any ideas?
Old Aug 27, 2002 | 02:42 PM
311's Avatar
311
Default Re: need help with a code 7 and 22 (311)
up to the top
Old Aug 27, 2002 | 06:00 PM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Code 22 Vtec system failure (I think). Make sure the vtec solenoid is granded right and or clean it. No clue what a code 3 is?????
Old Aug 27, 2002 | 07:23 PM
tinkerbell's Avatar
so you are getting codes?
how does it drive?
check you TPS sensor voltages (do a search)
and check that you have connected the solenoid properly (also do a search)
HTH,
t..
FASTESTCB7inQNZ
Nov 18, 2009 06:41 AM
wvudelsol
Dec 31, 2008 04:01 PM
toxicsynergy
Jul 29, 2008 05:18 PM
AllMotorB
Jul 1, 2005 08:22 PM
