3 wires on injectors
i have my motor installed in my 98 hx, but i ran into a problem with the injectors. the motor is a JDM GSR and i used a skunk to conversion harness to install the ecu the easy way but now i am looking at the injectors and i notice my wiring harness has two wires for each injector but the motor has three wires for each injectors.
a freind said i couldjust use USDM GSR injectors and scrap the injectors that came with the swap will this work?
also another friend was saying he just used his stock sohc injectors in his B16 JDM swap, will that work? arent those injectors too small?
well tahnks in advance for any info and anything will help.
