did search, mounts for b20 in EK?
i did some research on this, on other sites, some say you can use stock ek mounts? and just the rear SI bracket, some say use LS or GS-r mounts? what is the right answer? and please answer if you have done this swap or know a link to somewhere that has pics of it. thanks also, i know i use the delsol or si ac bracket for a/c, will i have issues wit turbo fitment? thanks
Re: did search, mounts for b20 in EK? (kwik2nec)
Use your stock upper tranny mount, b-series front tranny mount, 99-00 si rear upper mount, your stock driverside mount with 99-00 si timing mount bracket that bolts to the block, and whatever the appropriate a/c mount is for your a/c. I never looked into that, I just used a normal integra mount and took my a/c out.
DevinW
64
11-30-2002 03:12 PM
