ek swap help needed
Old Aug 27, 2002 | 09:44 PM
1 speedstar's Avatar
Default ek swap help needed
car:96 civic
motor:00 gsr with CX harness
i know that the EK has a 3 plug IACV and the GSR has a 2 plug. does anyone know the color of the IACV wire on the EK which im supposed to leave?
also, about the throttle cable, if i choose to use spacers what kind of spacers do you use? i passed by a couple of autozone/pepboys and they couldn't help me out. i was thinking maybe washers.
does anyone know if a jspec gsr throttle cable will work on my EK?
thanks in advance
Old Aug 28, 2002 | 08:09 AM
Default Re: ek swap help needed (primo ek)
anyone?? bump
Old Aug 28, 2002 | 09:27 AM
Jackson's Avatar
You dont use the orange wire, if I remember correctly. You also need to move the wires from the ecu pin. Take out pin A14 and move it to A12. Look here...
...A13 and A14 are not used on the gsr ecu. Also, why dont you just use a usdm gsr throttle cable?
[Modified by Jackson, 10:28 AM 8/28/2002]
Old Aug 28, 2002 | 11:21 AM
Default Re: ek swap help needed (Jackson)
[Modified by Jackson, 10:28 AM 8/28/2002][/QUOTE]
well right now i have my stock throttle cable and a buddy of mine has a jspec gsr cable. i can use mine but ill need spacers, and im not sure what to use as spacers. anyone happen to know the p/n of a gsr throttle cable? i've looked at acuraauto...parts.net but i can't find the section with the throttle cable. thanks for the wiring info.
BucCivicSi99
21
Mar 19, 2012 02:33 PM
mardoiii
Nov 2, 2008 08:23 PM
Phatch99
10
Jun 18, 2004 12:56 PM
ASHY-ELBOW
Aug 1, 2003 12:56 PM
Benny Z
Jun 30, 2003 07:00 PM
