obd II distributor for obd I set up?
Ok I just got my b20 vtec inside my engine bay, just waiting to start but I only have a distributor for a 98 gsr. My car is a 93 civic and the wiring is still for obd I. My question is, can I run that distributor for my engine? How could I make it work if possible? They both have a 2 pin and 8 pin connector. The 2 pin connector have the same wire color match, but the 8 pin connector have different wire colors for the wire harness and the distributor harness. Any help. Thanks
Re: obd II distributor for obd I set up? (Gonzo)
change the plugs from the OBD-II to the OBD-I distributor. i do it all the time. The only difference is that OBD-I has 2 plugs and OBD-II has 1. The wires are the same colors and its very simple
Re: obd II distributor for obd I set up? (yayaRl337)
SO...I can use my ba16a2 OBD 2 dist. on my obd1 wire harness?
someone help me out... wenrich@tds.net
Dave
Dave
Ruby Civic
03-09-2004 09:35 AM
Phat Corolla
06-18-2002 12:28 PM
